AOS
Started by MX45, February 23, 2005, 01:37:45 PM
MX45
I'm having trouble with armadillo object scripter. When I try to run the script in max is get and error that says
--Unknown Property: "pos" in undefined
Mike | If you never fail....you will never succeed.[/color]
MCMnut
I guess that's because you're using some "POS" objects.  ;)  :D  lol!
No, what it usually means is that the spelling is off somewhere with the object(s) you are using.  Remember that that you need the object name and file name to match each other.  Also, make sure there are no dashes "-" in the name as these get translated into the minus sign operator.  Use underscores instead.
Take a look at the names in the Max file it is crapping out on.  If you still need help let me know (usually email is best).
Jeff
Quote from: MCMnut on February 23, 2005, 09:18:02 PM
:D ;D
MX45
Everything is named the same, max file, slt, and texture tga. I used underscores, and some capiltal letters.
I'm can't get the script to run for one object, or when I combine them.
Say your max object, tex, & slt are: myobject.max , myobject.tga , myobject.slt--- then in the "objects" name -IN MAX it must also be called "myobject"
Select the object in max, in the  2nd box  on the utility tab is the max name (where it says box or whatever shape you start with when you create an object in max)
If you are using more than one of the same object you need to add an underscore (_) to the max objects name- not the max file name.
ex:  myobject_
MX45
#5
OH, I gotchya now. Thanks.
can't try it out now, but that seems like that's the problem.
edit, it works  ;D
