MX Reflex Skin DLC Packager v0.9.5.3
Started by mcm2boys, July 18, 2014, 05:54:26 PM
0 Members and 2 Guests are viewing this topic.
Finally it is possible to add your own skins to Reflex, TwistedDIRT brings you the MX Reflex Skin DLC Packager which supports building you're own DLC packages for Rider gear, Bike and ATV skins.
Warning: Using this program and the DLC packages that it generates will almost certainly cause your profile to be reset at some point. To avoid this you will need to deselect any custom rider/vehicle skins from the in-game Garage before you remove or replace any DLC packages. If Reflex tries to load a skin that is no longer available to it, then the game will crash and your profile will be reset.
The packager comes with wireframes for all of the supported gear and vehicles to get you started. You can create up to 25 custom skins per DLC (for gear DLCs) with DLC010, DLC011, DLC012, DLC013 used for gear, DLC014, DLC015, DLC016 used for Mx bikes and DLC017, DLC018, DLC019 used for ATVs.
Each skin set needs at least 1 texture to be replaced before it can be saved to a DLC, that is the diffuse texture, which is always the first tab on the texture tab set and usually is labelled 'Skin' or 'Plastics'. The grey light will only turn green (which means the texture will be included in the DLC package) when this skin has been replaced. Some other textures have been included in most sets if you want to play with them but they are not needed to make a new skin set. If you have changed the textures in a skin set but not the diffuse skin, then the light turns orange to tell you that you have made changes but the skin set will not be saved to DLC.
You only need this tool if you want to create skins. It creates DLC packages that you will be able to download from sites like reflex-central.com or mxmaniacs.com and then you can install these skins by copying the unzipped download files to your \Database folder in your MXReflex install folder. Remember to de-select any custom skins before you install a new DLC packages.
You can download the packager here.
Big thanks goes to JvdL and JamieT for their tireless testing and solid feedback that made it possible to make this program.   :-*
great work from all involved!!!
been super busy lately, but ill have a bit of a play! and maybe put something together.
cant wait to see JT's and JVDL's skins  ;D ;D
karpuha
It's unbelievable) We waited so long ... But I would like more detailed instructions) and are lacking visually see those pictures that are in the game at the moment. It is not clear what and where dolzhnobyt drawn. New whole, it's very nice)
Thank you for your work!
karpuha
Quick test) Everything works fine) Thanks again. Where are you planning to release the skins?
Good stuff guys.
I'll update Reflex Central tomorrow so that you can upload your skins there.  I'm sure Reaper will be doing the same to mxmaniacs pretty soon, if he hasn't already...
mototank
hey we have a bunch of guys in this ts3 and we could use some help i think 3 people are wanting to try at a skin
add me on steam "*DM*mototank" and shoot me a msg if your able to help
mototank
is there anywhere i can post my psd file of the troy lee honda i made so that people can have an idea of what goes where. i have labeled each part of the wire frame with the correct part name to the best of my ability.
Post a link to it here might be as good as anywhere.. If you are happy with people using it as a basis for their own skins then a PSD is fine otherwise you might want to use a JPG or PNG and reduce the size to something more easily viewable on screen.
If you haven't got anywhere to upload the file and you want others to be able to d/l it then email me and i'll stick it on the TD server for you. Otherwise mxmaniacs you can upload skin files, should allow you to u/l a PSD file if that's what you want to do..
mototank
im a bit confused about how the whole DLC thing works, ive managed to put 3 seperate models of bikes into one dlc pack however i'd like to know how i can have more of the same model in one dlc pack
for example i want to do more honda 450s but i already hav the tld honda in that place
one 450 of each brand per pack. one 250 of each brand per pack.  this just replaces the 3 dlc bike packs that came with reflex.
I seen that troy lee bike on mxmamiacs it looked sexy!!!
it kinda sucks but the best thing is probably to team up and release full packs as there is only three slots so it makes sense to have them full.
im thinking
-one pack needs to be all stock bikes.
-one pack for full US factory teams like, muscle milk Honda 450, troy lee Honda 250(your bike would fit here nice!), jgr Yamaha 450, star Yamaha 250, red bull ktm 450, Yoshi Suzuki, pro circuit kawi 250 (ive done this) ect
its going to be messy if too many single bikes get released. it will cause lots of game crashes if the person installs without swapping back to a stock bike first. this will make people pretty unhappy as you may have to restart reflex from scratch to repair the crashing fault.
anyone else keen on this project? any bikes you'd like to make for this project? any diffenent sugestions? I just don't want to double up!
twisted dirt bike pack 1- stock bikes
twisted dirt bike pack 2 - ama factory teams
Quote from: al167 on July 26, 2014, 12:01:27 AM
Nothing is replaced from the stock game.  These custom skin packs were just based on those skin DLCs that came with the game.  Basically just using them as a guide.
Uploads on Central are slightly broken at the moment guys.  You can upload packs like Mototank has done to the tracks section, and I will move them once everything is fixed.  The problem is to do with the size limit of the files you can upload.  It's a long story, but I've had to contact my hoster, and they're trying to figure out the problem.  All their suggestions so far haven't worked.  The issue seems to be server side, with something I've got no control of.
karpuha
Hello guys. this game quite old and new 2013-2014 bicycles will be suitable for it not all) But for UNLEASHED many excellent skins, 2009-2010 the bicycle were made. Whether as you think we can use skins from MCMFactory for REFLEX and whether there will be guys against? There after all there were magnificent skins of GALA, RUIS KOVALSKI and many other guys) I have no with them communications, probably someone from you know mail, or communicates with them?
WRATHCHILD31
Quote from: al167 on July 20, 2014, 03:59:44 PM
heres some of my skins so far!
Where can we get them? Can't wait ;D
Best news since a long long time! THX!
mototank
#14
im thinking
we can also have steam reflex teams pack like T-usa and my current team DM.
but i am totally up for that idea btw i also made the TLD skin for a lites bike with black number plate so if we wanted to put muscle milk in its place, we can.
if you are doing stock bikes or ama skins let others know whos doing what and for which bike.
#15
TWISTED DIRT skins packs so far:-
ama skins pack
Honda 250f- troy lee Honda- mototank
Honda450f -  2012 two two motorsports Honda (only because ive done it already and will save making another skin ;D ;D)- al167
Kawasaki250f- pro circuit kawi - al167
Kawasaki450f - factory Kawasaki ryan villapoto spec - mototank
yamaha450f- has to be JGR- mototank
yamaha250f- star Yamaha- al167
suzuki450f- Yoshi factory Suzuki-mototank
Suzuki250f- 2013 rockstar Suzuki -mototank
ktm250f- rockstar- xenah
ktm450f- redbull ktm- xenah
kx125- late 90's pro circuit 125(rc) - anyone?
any ideas on two strokes for the ama pack? maybe some classics like a carmichael spec pro circuit kx125, mcgrath yz250 or cr250??, ????
put your ideas up for the ultimate AMA skins pack!!!
or if you want to do one anyones welcome! :)
stock skins pack
Yamaha yz125- 2013-fillip42
Yamaha yz250- 2013-fillip42
Yamaha yz250f- 2009-fillip42
Yamaha yz450f- 2009-fillip42
Kawasaki kx125- 2013-fillip42
Kawasaki kx 250- 2013-fillip42
Kawasaki kx250f- 2009-fillip42
Kawasaki kx450f- 2009-fillip42
Honda cr125- 2007 model - al167
Honda cr250- 2007 model - al167
Honda crf250- 2009model - al167
Honda cr450- 2009 model - al167
ktm125- 2014 husky- xenah
ktm250- 2014 husky- xenah
let me know what you guys want to do and ill add it to the list and update it everyday!!
these packs will hopefully be done and ready for release in the next couple of weeks!
xenuh
I am working on a RedBull KTM at the moment, I Could do that one?
WRATHCHILD31
#17
Quote from: al167 on July 27, 2014, 06:43:06 AM
any ideas on two strokes? maybe some classics like a carmichael spec pro circuit kx125, mcgrath yz250 or cr250??, ????
ot if you want to do one anyones welcome! :)
For 2-stroke maybe some classic MOTO XXX dice graphics for cr, yz or rm? Or some SPLITFIRE kx? Bring back the old times, this would be nice 8)
#18
Xenuh no probs ill pencil you in above, do you need a template?
I can send you one if needed
wrathchildjunk- those both sound like great 2 stroke skins!! that spitfire bike do you like top or bottom pic? also added a chevy trucks kx250- would be cool for the 250 too!
WRATHCHILD31
It's hard to make a decision cause every classic splitfire/pro circuit design is pretty cool! Check out this:
Last but not least take a look at this one ;D
