DLC files needed to use custom tracks with splines
Started by mcm2boys, April 04, 2014, 05:35:45 PM
Reflex Splines are finally ready for you to try, when some tracks have been released that include splines.up.zip]DigitalEarthworks v0.8.2.7[/url]
For this to work some extra beta slots have been created, 8 for Sx tracks and 8 for National tracks. Modifications to the MXLeaderBoard file in the reflex root folder is also necessary to make these splined custom tracks to work online. If you don't already have Freeride beta slots installed then you will also need to install these from this post before starting Reflex, you need the bit about Beta Track DLC files. Once that is complete you can install these new files with the following:
-1 Download the 2 files from the links below.
-2 Identify the Reflex install folder, this is usually something like C:\program files\Steam\steamapps\common\mx vs atv reflex\
-3 Extract the files from the zip files, there should be 2 MXTables_DLC008a files and 1 MX07Leaderboards.bxml. To get around windows security you might need to copy these to your desktop first and not extract the files directly to your Reflex folders.
-4 Copy the MXTables_DLC008a.database and MXTables_DLC008a.package files to the \Database folder in the Refllx install folder from step 2.
-5 Copy the MX07Leaderboards.bxml file to the Reflex install folder from step 2. NOT the Database folder.
Start up Reflex and you should be ready to rip..
Links:
Extra Sx|Nat beta slots: MXTables_DLC008a.zip
Updated MXLeaderboard.bxml: MX07Leaderboards.zip This goes in the Reflex install folder NOT the database folder
