i need some help please
Started by Allen, September 14, 2004, 08:59:39 PM
Allen
  Hey i have a problem on my hands its realy anoying me now i got a track i made that i cant get in the game couse it crashes yes i do have mcm2 instaled in the the right place along with dillo i have made other tracks with custome objects and never had this problem befor i have tried rebuilding the whole project 3 times now and i do use MOA but like i said i have never had this problem with any ove my other tracks with custome object its just like the thing that hapens win you dont use MOA but the only thing i can think of is that i notised some one changed my front setings in notepad could this couse a problem win MOA trys to reright the file? if so whats the seting to get it back to normal please help me out i would realy like to play this track in the game.
MotoX395
Do you run it through APM? It is easy to forget that sometimes. :P
aaron.270
Are you using any of the newer custom objects with multiple .tga files or ones with alpha channels that you would need to place using dillo too.  Some of the newer objects that are created cannot be placed using regular armadillo.  I would check the description of the objects you never used before and see if you need to use dillo too to place them.  Or you could also save your project in another location so you have two copies, then just start deleting objects and trying to bundle until you find the object that is causing the problem then fix it or remove it in the original project.
TMD_MickyD
Allen
it was a object that needed placeing with dillo 2 thanks for the help
