Bales lots of em...
Started by BombX3, September 02, 2004, 10:01:30 PM
BombX3
Ellooo,
        Is there any other way to put more than 200 bales on my track, exept of 3D max cause i dont have it. Cause I know you can link them all in max but is there really no other way :-\
Thank you
Merci
Gracias
Vielen Dank
Dank u
MX45
sometimes APM will cooperate with me and 200+ objects, sometimes not. Not really sure what the factor is there, but I guess you could hand edit your scn too maybe.
Or place them all in D2. It even has a terrain and "last object placed alignment thingy do dad" to make objects, especially bales, as painless as possible to place.
good luck.
Mike | If you never fail....you will never succeed.[/color]
Kazam
u can get up to like 500 costum objects to work ingame
Place em all in dillo  then save/run apm and close
then open D2 and pack it
it will work
BombX3
sweet cheers...i pressume once u go over 200 though theres no turning back and u just gotta keep placing, cause dillo wont open it after that
Kazam
yes it will still open up   no probs there
just keep doing the same   everytime u open the project in D1   u need to APM it aftewards  even if u didn't place any objects... just do it
Daniel Ahlgren
and who learned most of you guys that it works ;)
BombX3
AMA_DirtTwister
I'd like to clear something up.  Once you place a custom object and use APM, you need to use APM everytime you save your project in Dillo.  If you save it in Dillo and then try to reopen your project, it will fail.
The typical failure scenario is to work on your project. Use APM.  Keep doing that and then make one last change, but you have to go somewhere and you just save it in Dillo.   When you come back to it a day, week, or months later it won't open in Dillo.  You just need to run APM and then open it in Dillo.
What I do is everytime I save, I use APM.  Then to be extra safe, everytime I start reworking on a project I run APM before opening the project in Dillo.
AMA_DirtTwister - http://dirttwister.com
BombX3
