Missing DLL for Dillo Too?
Started by mcm2boys, August 16, 2004, 04:21:40 AM
If you are missing the Dillo Too DLL you can get it here:
http://www.twisteddirt.com/mcm2boys/d3dx8d.zip
TNT_wfo
Anyone else have a problem with the latest version moving the startline away from the finishline? Just by opening a new project in D2, my startline would move about 30 seconds of laptime back from the original finishline. I tried importing a copy of my spline but to no avail.
thnx
Kamloops BC, dirtbike heaven!
Does it move the startline spline points, or just move the line to a different set of spline points? If it's moving the startline to behind the finish line then you must have a really short first lap?
Maybe you could send me the TDF file to take a look at it here.
TNT_wfo
Perhaps some pics can show. All I do is open a project with it and it moves start line back. Here is pics of  my latest release Holiday Hillz, which has a laptime around 1:50. One pic of Armadillo and second one of D2 (97b2)
hmm ok it looks like you started the Spline in a different place to where you set the Start line, and then set the start finish once the spline was complete. Is that right?
D2 assumes that the first point in the spline is the start line, which is why i think it has moved the start line to there. I'm guessing this doesn't happen with all your tracks unless you move the start/finish from the first spline?
TNT_wfo
Ok your right on both counts. I just made a new test spline and put the finish at the same point as the first node. D2 didnt move anything.
thanks.
