Reflex Surface Creator Tool
Started by JamieT, January 09, 2015, 02:55:28 PM
0 Members and 4 Guests are viewing this topic.
gary664
@MCM, yes, I do have 4.5 installed..  Although I couldnt find it in my control panel, but when i tried to re download it, it said i already had it installed..
Baja1000McCoy306x
Strange, I run that too. Well now I'm stumped as to what's causing problems on your end, i apologize
so you have 4.5 but do you have 4.0 installed as well? some software seem to need specific a version of .NET..
gary664
Yes, apparently I have 4.0 installed as well.. Or at least when i tired to specifically install 4.0 it said I also already had it installed.. I tried to install surface tool on my laptop, but the same thing happens.. Nothing shows up when i click on the application..
redrider197
I'm having the same problem. I did what was suggested with re-installing .NET 4.0 and 4.5 both of which said, "I already had them or higher versions". I also did the same with Direct X 9 and nothing changed. I have windows 7 64 bit. I click the program and it does the wheel for a few seconds and then just disappears. I also tried the older version except with v 1.2 it says Reflex_DX_v2 has stopped working.
Have you guys tried running as admin or tried any compatibility modes?
gary664
Yes and Yes.. Ive fiddled around with all the compatibility settings and couldnt get anything to work..   There is only suppose to be three files in the folder correct?
Yes only 3 files.
First time I ran the surface creator though Win 8.1 didn't seem to trust the program, but once I chose "run anyway", it's worked each time no problem.  Maybe this is an issue for you?  Have you tried disabling your anti virus and then running it?
redrider197
hey guys, so I still have no luck. I run it as admin, I've messed with the compatibility. I've disabled my antivirus and even done so while extracting the zip file. The program just doesn't like my computer lol
redrider197
I just tried it with my laptop and no luck either. windows 8 on this but its 64 bit as well.
gary664
I did the exact same as redrider..  No luck still..
gary664
Unfortunately then, I'm all out of ideas.  The current version is working fine for me on a Windows 8.1 64 bit machine.  It's very puzzling and I'm sorry it's not working for you.
gary664
well i do appreciate all the ideas and effort.. Ill keep trying to figure it out, once i do ill share the info
Not sure if this will help, but i also have .NET version 1.1, 3.5 and 4.5 installed along with the 2.0 SDK.
gary664
I installed 1.1, but still nothing.. Is it possible is has to do something with WinRAR?
Jamie included an extra dll in the zip file, but mine works if i rename that so i'm not sure how critical that is. It might be corrupting the files, i can't see why if it works on other files but you never know, try using something else - i use 7zip.
If that fails take a look at this - if you haven't tried it already - to find if it's missing any DLLs:
http://stackoverflow.com/questions/27786156/c-sharp-application-wont-run-on-other-machines
ctrivelpiece
Anyone tell me where im going wrong here? I make a simple cylinder (blender), export in collada, try to load it in the surface creator and this is what i get:
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
   at System.ThrowHelper.ThrowArgumentOutOfRangeException(ExceptionArgument argument, ExceptionResource resource)
   at System.Collections.Generic.List`1.get_Item(Int32 index)
   at Reflex_DX_v2.Form1.MakeSurface(String myfilename, Device device)
   at Reflex_DX_v2.Form1.open_dae_button_Click(Object sender, EventArgs e)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnClick(EventArgs e)
   at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ButtonBase.WndProc(Message& m)
   at System.Windows.Forms.Button.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Any ideas?
Can you send me the Collada file please?  I'll see what's going on.
